Andy,
(Good one Al, here with go with the unobtainium again
First, what kind of sparks did you get when you ground into that? I ask because you caught me off guard with your thoughts on type of material. My first guess without having the part in my own hands would have been aluminum.
Now for a list of things:
1) ER70S-2? That would not even be a starting place for alum nor cast iron of any grade. If it is a cast and not alum I would suggest 309 stainless. A little bit at a time, keep the heat down. Do a se
arch here for using stainless on cast iron. There have been several threads with great ideas.
2) Don't mess with the trick electrodes. Many will work after much practice but they are way too expensive and can usually be replaced with regularly available consumables. And look at their base, usually nickel and or chromium, basically, stainless steel.
3)
CLEANING!! Regardless of material, Alum or Cast, it will need good cleaning by several options maybe even mixed together. If it is a years old cooling system the material has absorbed a lot of contaminants. You will need to use either a Muriatic acid, acetone, heat, or many other options to get the base clean before trying to weld it. And a stainless steel brush.
