There is always an original design pressure, which is equivalent to MAWP. But generally the actual working pressure is normally set below the MAWP. Critical lines, or equipment like steam drum, air reciever are installed with safety relief valve to prevent over pressure. When the lines are found not be able to operate on required operating pressure, derating below the original design conditions to provide increase in corrosion allowance normally happens.
