Agree with Tim
I know.... You didn't ask for criticism.
While GMAW short circuit can be done in compliance on base metals that thick (you have proven it with the PQR) Doing it out in production, with all the vagaries of fit-up, technique, position, and access may prove to be much more difficult to harvest the quality I know you want.
The alternatives available with wave form controlled processes (both short circuiting, spray, and hybrid) are both more productive and typically able to achieve higher quality with less effort and skill level.
I agree as well, but when the higher ups are dead set on something because of what resources are available. What can you do besides showing them what's in the pudding.
Who do you think will take the fall if these "inappropriate" welds fail in service ?
The "higher-ups" will be nowhere to be seen.
Up to you !
hevydoti432,
It does not look like anyone answered your question about 1.1 vs 2. For Short Circuit mode, it is 1.1 for deposited weld metal and material, if its less than 1/2". 1/2" and over its 2T,2t, per Tables QW-451.1 or QW-451.2. It does not matter if your using standard Short Circuit or a wave form technology like STT or RMD. Now, I have a question for you. Are you using GMAW Short Circuit for the root pass only? The company I work for is using RMD for plate work for the root pass with some very good success. Let me be clear, for root passes only. I think RMD is better than STT because it seems to handle poor fit-ups better than STT and the equipment is more versatile.
