First, buy a copy of D1.1.
Your welders will have to be requalified because D1.1 is more stringent with regards to the visual acceptance criteria.
The SWPS you purchased from AWS isn't going to tell you or the welder everything you need to know to make a code compliant weld. You need to review all the requirements as they apply to the work you are doing.
