Up Topic Welding Industry / Inspection & Qualification / 6G Up or 6G Down
- - By Josh Waymack Date 12-18-2019 19:53
Hey guys, new here to the forum. I have a question. So I have tested lots of welders in my career and have recently moved into a weld instructor position. I walked into a young mans booth and his 6G weld test was on a 45 deg. But was braced at the top and pointed downward. It caught me off guard and as I thought about it in my mind it should be acceptable...Sec IX shows an illustration & shows the axis and shows it to be set at a 45deg.   Can anyone give me feedback?
Parent - By 803056 (*****) Date 12-18-2019 19:59
Makes no difference provided the axis of the pipe is 45 degrees to the horizon. I don't believe Section IX or any other code specified whether the pipe is supported from the bottom end or the top end.
Parent - By welderbrent (*****) Date 12-18-2019 23:55
Good Day Josh,
WELDCOME TO THE ORIGINAL AWS WELDING FORUM!!!  THE GREATEST WELDING FORUM IN THE WORLD...BAR NONE!!
I agree with Al.  Axis is the same, joint position is the same.  Only difference is which side of the pipe/tube gets attached to the support frame/pole.  That has no bearing on the test position or results in any code I am even slightly familiar with.
Have a Great Day,  Brent
Parent - By jwright650 (*****) Date 12-19-2019 20:41
Hi Josh,
I agree with Al and Brent. The main issue is in regards to the joint and the axis that it is on. Where it is supported doesn't matter.
