Up Topic Welding Industry / General Welding Discussion / deposited weld metal in branches
- - By senthil Date 04-09-2007 17:26
im a graduate student,now im working in welding line,i have a doubt regardig the above topic,here we are using o-lets(fittings) in pipes for branging,ans me how much we need to deposite like that joints.
Parent - - By js55 (*****) Date 04-09-2007 18:03
O-let welds are essentially a combination of a butt weld and a fillet weld. They are  most often overwelded far in excess of what is necessary. And for good reason. To really know what is required you need to call the O-let manufacturer and determine from them what the calculated nominal wall thickness is of the O-let in question. The problem is, each manufacturer calculates and forges them differently. So your data proliferates to the extreme, and is manufacturer sensitive.
So what most people do is just weld out past the 'bevel' that has been forged and/or machined into the fitting and then add a whoppin fillet, creating this 'knot-on-a-pyramid' appearance that most people agree is adequate.
This works very well for most O-lets, say 1/2" to even 6" or 8".
Its when O-lets in the range of say 24" are used on thinner wall pipes (horseshoeing your header), or when the O-let nominal size is the same as the header (I've seen inspecotrs insist so vehemently onthe 'pyramid' look that the weld ended up wrapping halfwya around the pipe), that the "pyramid" philosphy really breaks down. Or when welding stainless O-lets when you wish to reduce distortion.
Parent - By CWI555 (*****) Date 04-10-2007 03:19 Edited 04-10-2007 03:25
There is some backing and definition for this matter. Code inquiry 11-10 published in 1993 later code case and subsequent inclusion in all current codes clarified the issue.
I will attached some graphics that should explain it. (the attached images are per B31.3).
You are correct in that some inspectors wrongfully insist on to much weld, but by the same token, some welders absolutely refuse to understand why the reinforcement fillet is
necessary. For further information please see B31.3 figures 328.5.4 A, B, C, D, and E and code inquiry 11-10.
gerald
Parent - - By 803056 (*****) Date 04-09-2007 19:24
In the absence of asking the manufacturer what their welding requirements are, the piping codes general require a complete joint penetration groove weld plus a reinforcing fillet weld. The size of the reinforcing fillet weld is dependent on the specific piping code, not the operating pressure.
One manufacturer that I have spoken with, will not warrantee their product unless the groove weld is a full sized complete joint penetration weld and they insist on a reinforcing fillet weld all around the fitting. Different fittings are used for different applications, i.e., pressure and other operating considerations.
Many of the integrally reinforced branch fitting I have seen in the field were not welded in accordance with the appropriate piping code and they did not meet the requirements of the manufacturer.
There are alternatives to using the integrally reinforced branch fitting (and the accompanying welds). They require some effort on the part of the design engineer to properly size the branch fitting and the reinforcement ring (if required). However, there may be an opportunity to reduce the distortion in the run pipe by minimizing the weld size requirements through design.
The intent of the integrally reinforced branch fitting is to reduce the engineering time required to design each branch connection by utilizing standardized fittings that have been designed and tested by the manufacturer. The integrally reinforced branch fitting (with full welds) eliminates the need to design (and install) reinforcing rings around the branch fitting to compensate for the volume of base metal (in the run pipe) removed to accommodate the branch.
Branch fittings that are not welded as per the manufacturer's requirements are not going to perform as they were intended. Groove welds that are not welded to completion can act as notched stress risers. What is often over looked are the stresses induced as the run pipe moves longitudinally due to changes in temperature. Those longitudinal movements induce bending loads on the branch fitting. Fatigue and cracking can result at stresses much lower than yield.
No insult is intended when I say that there are very few welders that have the training needed to perform the calculations necessary to design a branch connection in the field.  However, I've had welders say that the full weld isn't required because the system isn't operating at full pressure. The same welders lose the ability to speak when they are asked what piping code is specified. They get glassy eyed when they are asked what operating temperatures, pressures, and allowable unit stresses are permitted by the applicable piping code. The glassy eyed look becomes the 1000 yard stare when they are asked "what is the magnitude of the bending forces on the branch fitting due to thermal cycling?" Contrary to the belief held by many pipe welders, few welders are qualified to make those determinations.
My advice is to contact the design professional and the manufacturer if there is a question about the welding requirements for a particular fitting and application
Parent - - By js55 (*****) Date 04-09-2007 20:10
803056,
I would agree with you except, the problem is that you don't know where to end your calculation of the full pen groove weld cap/thickness. Where does the groove weld end and the fillet begin? You can't use the machined bevel for reference, especially in the jumbo O-lets. They will vary depending upon the manufacturer. Thats why contacting the manufacturer is required if you wish to be precise. Although, in most instances (smaller O-lets) I personnally don't recommend that. Its more trouble than its worth generally. Just add more weld metal. It may seem like a waste but it is easier.
Quite frankly 1500's don't really present a problem. Neither do 3000's or 6000's in most sizes. Its the bigger/heavier ones that really cause you to question the overkill method,and may drive the necessity to be more precise.
Parent - - By CWI555 (*****) Date 04-10-2007 03:33
I would have to disagree with just add more weld metal. Sometimes more is not better. The inspectors you spoke of that pushed massive amounts of welds I doubt understood that. Added heat, added stresses in general. Correct me if I am wrong, but the ideal weld would be the minimum necassary to meet the engineering, code and workmanship standards.
Respecfully,
Gerald
Parent - - By js55 (*****) Date 04-10-2007 13:40
Gerald,
There is nothing you said that I disagree with. I think the problem, as I have expereinced it, stems from the fact that without contacting the manufacturer for min wall calcs on the O-let nobody really knows the min groove weld allowable, so overkill has become common industry practice. On smaller O-lets the weld will generally start at the shoulder of the O-let and taper out from there so that the toe of the fillet lies outside of the rim of the O-let. From the few calcs that I have run this is far in excess of what is necessary.
My expereience has been that you walk into any fab shop in the country and observe their practices on O-lets and folks are just welding them up until all concerned are comfortable with the amount of weld metal they see (from the shoulder to the header in a sloping fillet). Nobody really knows how much less they can precisely get away with, and nobody is even really asking.
Now this may sound scary, and perhaps in a sense it should be. Except, as I have asked in here before, where are the failures that would demonstrate we have a real problem. This isn't an argument for lacksadaisical controls, but still.
And as for more not being better, that is certainly the case with stainless where the results of excess rears its ugly head
Parent - - By js55 (*****) Date 04-10-2007 13:43
I'm just guessing here but the issue may be that nobody is complaining because there are no failures, and so nobody puts forth the effort because its too much trouble.
Parent - - By 803056 (*****) Date 04-10-2007 15:41
It is just as likely no one wants to air their dirty laundry or stir up the muddy water.
Parent - By CWI555 (*****) Date 04-11-2007 03:31
I would have to agree with that one Al
