Try looking on this site.
www.twi.co.uk
Havent been thier for awhile but they used to have some good stuff.
Not sure where you can find it but there was a great article written by Omer Blodgett titled "Why Do Welds Crack". Think he worked for Lincoln Electric. Might do a search and try to find thier web site and see what they have.
hope this helps ya
regards
kam
I think that article by Omer Blodgett is available at lincolnelectric.com
CHGuilford
More specifically, go to www.lincolnelectric.com/pdfs/knowledge/articles/content/weldcracking.pdf
The Lincoln site has many other other good articles as well.
In addition to kam's and Mr. Guilford's useful recommendations I suggest you the following:
1) it is possible that your college library has AWS's Welding Handbook and/or Jefferson's Welding Encyclopaedia. You'll find a lot of material there.
2) On the upper right angle of this site's homepage there's a small white window. Write "cracking" on it and then click on "Search". There are 28 references which you can look at.
By the way, what does MPCC means?
Sao Paulo - Brazil
You can also search the "Welding Journal" technical articles which are archived on this AWS website.
