Up Topic Welders and Inspectors / Education & Training / Coupon bender
- - By gregdlabach Date 01-26-2001 15:51
I am looking for a plunger-style coupon bender. 15 to 50 ton capacity. Nothing fancy, manual analog machine is OK. Can't seem to find any manufacturers of these items.
Parent - - By Paul Gilley (*) Date 02-03-2001 22:30
Try Fischer Engineering Co., Dayton, Ohio. www.fischerengr.com. They manufacture several different types of bend testers. They are rather expensive. A very useable coupon bender can be fabricated using the specifications in AWS D1.1. Refer to section 4.8.3 and Figure 4.15 for measurements for standard thickness of materials. If the metal is thicker than standard the mandrel diameter is four times the metal thickness. The Die part would be sized accordingly, allowing for metal thickness. A hand operated hydraulic press could be used for power.
Hope this is helpful.
Parent - By gregdlabach Date 02-07-2001 17:56
Thanks for the tips.
Parent - By MBSims (****) Date 02-06-2001 04:59
Try www.tech-aid.com.
Parent - By magodley (**) Date 02-07-2001 22:48
See Hobart Institute publication "Recommendations for teaching weldng" for excellent drawings for a bender to be powered by a port-a- power or similar hyd. source.
