Vertical Up is usually much quicker to get the hang of I've found and because the work is usually below you, or mine is I'm not sure about your's, the arc is more visible. Rather than welding downwards covering it with the torch as you go. I weld from side to side horizontally if I can because I find it much easier to keep it moving smoothly. I usually rest my hand on the work and guide the torch along, a habbit I regret when it gets a little too close for comfort and my glove begins to steam or catches alight!
The heat going in depends quite a lot on the direction you have the gun as well as it's angle, your backhand (Pull) and forehand (Push) welding. If you point it the way you're moving, push, then you can put a lot of preheat into the area just infront of the arc by tipping your gun by about 30 - 40 degrees into the work, so the wire makes a smaller angle with the work. The smaller the angle on the gun, the less heat infront of the arc but more on one spot. So for big long seams you would need to angle the gun, I do anyway. If you pull the gun you will put a lot less heat infront of the arc and angling it into the work, so it's more horizontal with the work, now will just heat up the weld you're leaving behind the torch as you go.
I'd just have a muck about on some scrap bits the right size and you'll find the angle you need pretty quickly. Remember that if the real thing is massive compared to the bits of scrap you'll proberly have to end up putting lots more heat in because, obviously, as you increase size there is more metal to soak up the heat.
For me welding MIG, actually FCAW I keep the arc straight into the parent metal, but with outside winds, keeping the nozzle
straight into the metal reduces the chance you'll get porosity. And keep in mind, with vertical up, you can bury your arc
length with your wire speed where it almost pops constantly and really digs or you can put a smoker on there...it just depends
on what you want.
The Bridge used to give a vertical down stick, but I hardly doubt that too many companies give a vertical down mig.
John
