Hi guys,
After reading several posts regarding fumes when welding and a possibility for health concerns, I have a simple yet effective fume venting rig I made for where I work. This is the original prototype I have at home. There are certain frames I weld at work that require an extension added to it to lengthen the height or width for a customer's specification. When welding the extensions to the frames, there is a pliable bonding like glue that is in the grooves of the frame to adhere the material that covers the frame. During the welding of the inside corners of the addition, the glue ignites and produces a terrible acrid black smoke and even my exhaust fan can't remove it fast enough. I made this unit to mount the nozzle close to the welding area and the blower is across my welding table and venting towards the exhaust fan. It has solved my problem with these fumes and does not affect the MIG gas at all since it is of a low enough volume. The blower is nothing more than a small squirrel cage blower a friend gave me from some scrapped equipment. I can adjust the angle and heighten it with an arrow magnet if necessary.
I tried my shop vac prior to making this unit, but the shop vac has too much suction volume and affected the MIG gas flow. I would guess if someone would fabricate a special nozzle cover with small orifices in it, that may reduce the volume sufficiently, but may cause the vac motor to heat up. Anyway, just a way someone may find useful that will help them a bit.
http://i55.photobucket.com/albums/g159/yorkiepap/DSCF0223.jpghttp://i55.photobucket.com/albums/g159/yorkiepap/DSCF0224.jpgDenny
