Hey Chris,
You're quite welcome. This was the first car in all my years of welding I had the opportunity to do virtually a "frame-up" restoration. And to get an initiation with a classic like this....LOVED IT!!!! The first day I arrived and walked into his garage, I guess my jaw dropped. This car is magnificent....and I'm not a Ford guy. I do love the classics though, no matter what make, especially the '60's-70's muscle cars. Now, those were cars.....each had their own design look that made them so individual. Not like today's Euro trash look.
The owner, Dave, really took his time and did most of the "grunt" work with cutting, fitting, and all the finish grinding and painting of the new metal. I told him I would only do first class work and no half-a$$ mediocre crap, since my side "hobby" is important and I want new customers and good recommendations. He agreed and said he would accomodate anything I needed to do to make it first class. We had a lot of fun and, even after 40 years of welding, I still managed to learn new techniques. I will say this was the first time I ever welded flat on my back for hours at a time.
OK...FOOD FOR THOUGHT:
I will offer you some suggestions so you can start doing some prep.
1. Definitely go to school and really learn all you can.
2. Practice...practice...practice!!
3. Get the "feel" of your welder by welding same thicknesses, and different thicknesses together. You will see how metal will bond and bind correctly when you learn technique: heat settings, wire speed, gas flow, and travel speed. Practice...practice...practice.
4. Prior to starting, set up your equipment for the metal you will weld by using scrap pieces the same thickness. Scrap the scrap first....not your panels. Get the "feel" of the metal.
5. TAKE YOUR TIME!!!! Do not rush any process. If your eyes start to tire, or things start to look blurry...STOP!!!!! Let your visual system get accustomed to welding gradually.
6. SAFETY!!!!! Protective clothing, good leather gloves, steel-toe boots, safety glasses. I must say I prefer the auto-darkening helmets.
7. TOOLS: 4" angle grinder a must....can use both 4" grinding wheels and cutoff discs; 6" & 11" vise-grip welding clamps; 2" thru 6" C-Clamps; Arrow welding magnets...25 & 50lb; needlenose pliers with cutter, wire brushes, 12-15" Crescent wrench which you can use to make some nice small bends on the metal for tight spaces or corners. You can get most of these items reasonably on E-Bay or Harbor Freight to save a few bucks.
Chris, you will find you will enjoy a project like this immensely and look forward to each day's progress. Remember, quality work is paramount.....think about someone else doing your restoration job and would their work satisfy you? OK....you keep in touch and don't hesitate any questions.....there are no dumb questions...sometimes dumb answers though.......Denny
