Hey Sourdough, I get the biggest kick out of my kids when they start talking about all of the power etc. in the nissans, mitsubishis, toyotas, etc., you get my drift. I think back to a 65 Olds 442 that I had, a 68 Chevelle Malibu SS that I had, and a torrent of other cars that I had the pleasure of driving or riding in. You could FEEL the horsepower!!! You also can't beat the tones and sounds of those motors, either the high revs of a small block or the deep throaty roar of a big block and the feel of a descently ground cam. I do miss that, I don't miss the tickets that went along with them. Have a good one and enjoy your building process. Regards, Allan
I built up a 307 (1968 chevelle)mtr. I use to run at the drags(lost track after 52 wins) I bored mine .030 over used, jhans pistons, used chrome seal powered rings,fit my own ring end gaps,crossed hatched the cyl.walls,balanced the rods,pins and pistons.plastic gauged all the rod bearings&main bearings.I ordered the highest horse power hyd.cam(stock chevy)that gm made.I used TRW semi-solid lifters(back off till they clatter than snug them up till they stop).Had the heads milled& the studs pined with a valve competion valve job.Installed a dual point dis.ign.with a high out put coil.Installed a 4bbl.manifold (torker)with a duel feed double pumper holley carb 650 carb with a set of hooker headers(custom tuned).You talk about SMOK'EM up.I had a lot of fun with that rat motor lot of guys would'nt believe it had a 307 in it.I got protested a number of times.I also painted the car my self(it took me 6 weeks painted it vitamin C with lace & some cobwebbing+10 coats of clear laquer)if a fly landed on it he'd slip and break his neck.Maybe this will give you a few ideas sourdough
