AWS D1.1 is the American Welding Society's Structural Welding Code. AWS D1.1 covers design, construction, and welding requirements of buildings as well as bridges, and also has a list of pre-qualified welded joint configurations. AWS B2.1 has a list of pre-qualified welding procedures. If you use one of them you do not have to perform a PQR. Only qualify your welders. But you must follow the procedures verbatim. If you change any essential variable, you must re-qualify your procedures. I am not familiar with the second standard you quoted.
