Didn't see anything in D1.1 Sec. 3 or its commentary concerning welding steel with CVN requirements.
Did find a paragraph in C-4.12.4.4, in the WELD METAL column, 1st paragraph, 3rd sentence; I hope this helps you
Are you sure what you read wasn't about CVN requirements for the base metal? Seems to me if CVN testing is required for the weld metal, the only way to get those is testing the weld, which means a qualification test.
Hg
I do not think the code is crystal clear on this question, but I feel pretty confident that the following is the code's intent.
If you already have a prequalified WPS or are putting one together, and you need to establish CVN results for the WPS, then you need only run CVN tests. The logic behind this is the code already implies that we should be confident that the prequalified WPS will provide necessary weld strength, soundness, quality, etc. When CVNs are mandated by contract specs, this only implies that toughness shall be measured not the other properties which the code has already deemed unnecessary to verify through testing. Just because toughness is now an issue it does not mean our faith in the procedure to give acceptable strength, soundness, quality, etc. should be shaken.
Section 4.35.3 [editorially corrected reference] clearly states what must be done if an existing qualified WPS is applied to situations where CVNs are mandated. (1) You need only to do a test plate for CVNs. (2) You have to tighten the EV ranges on the existing WPS to include Table 4.6 variables. (3) You must revise or replace the original PQR and WPS taking into account the new test and Table 4.6.
There are always exceptions, 3.14(3) states if PWHT is required when toughness testing is also required then the WPS cannot be prequalified, that is you need to do a full test plate with CVNs, bends, tensiles, etc. Also Table 3.1, note b states that the allowable filler metals for certain base metals need to be tighten on prequalified WPS; you would NOT need to run a test for bends, tensiles, etc. but you would need to revise the prequalified WPS to tighten the filler metal requirements.
Short answer, just run your 3G up and be done with it.
It's taken me a while to get back to this issue, but I did a little more looking. I think D1.1:2004 section 2 summarizes it best- I don't get into section 2 that often, so it is easy to overlook. Take a look at paragraph 2.2.2. I think it is saying that the engineer should specify if weld metal classification by the manufacturer is enough, or if actual testing is requried.
