Up Topic Welding Industry / General Welding Discussion / how to weld 4130 (locked)
- - By Aldridge6670 (*) Date 12-28-2006 14:33
I heard you can use stainless steel 310 and 312 filler metal   any  pointers
Parent - - By chuck meadows (***) Date 12-28-2006 16:42
Although the recommended filler metal for welding 4130 is covered by ASM specifications 6457A (4130), a stainless steel filler metal is acceptable (312 preferrably because of the higher strength of a 309) if lower joint strength is acceptable. Lower strength filler metals can reduce cracking in some applications. In any case, low hydrogen filler metals must be used, and they must be kept dry to avoid hydrogen cracking. If you will check back through the archives of this Forum you will find that there have been much discussion and recommendations about welding 4130.
Chuck
Parent - - By Aldridge6670 (*) Date 01-01-2007 17:26
Chuck   what gas to use   straight argon  ??? that was something else I should have asked .
thanks
Parent - By Lawrence (*****) Date 01-02-2007 01:29 Edited 01-02-2007 01:32
Ald
100% argon for GTAW  for any filler choice
Assuming you go with the 300 series stainless  98% Ar/2% O2  For spray transfer GMAW
Other GMAW gasses can be used if you go back to 4130 or carbon steel fillers
