Up Topic Welding Industry / General Welding Discussion / Self Shielded FCAW w/ Ceramic Backing (locked)
- - By Sean (**) Date 01-10-2007 15:53
Welding 1/4" plate (mild steel) tank with self shielded FCAW wire (1/16").  Was considering ceramic backing.  I was wondering if anyone has had any experience with this type of FCAW wire with ceramic backing.  Any suggestions on for wire or other precautions we should use?
Sean
Parent - By hogan (****) Date 01-10-2007 17:49
i see it done all the time with nr-232, these are welds that are ut'd and pass fine
