Up Topic Welding Industry / General Welding Discussion / Tig Heat Settings (locked)
- - By crenshawjm (*) Date 01-13-2007 00:08
i got a question, i have a tig calculator and it does not go as low as i need information on.... what heat setting should i run on SST 0.025" Thick ? and help would be appreciated. i think somewhere between 5-20 amps ?
Parent - By 357max (***) Date 01-13-2007 01:28
Some welding book authors have printed that for every 1/1000's thickness 1 amp of current is required. Therefore the 0.025 would require 25 amps and Stainless Steel would normally require less. A problem will arise when welding at this amperage and that is too large a diameter tungsten. This low amperage would require a maximum tungsten diameter of 1/16". A better choice would be to drop a size to 0.040 diameter. And the argon flow rate would be reduced to less than 10 cfh.
