Hello folks, I do a lot of 1" plate certifications. To start, I place the vertical and overhead plates face to face and tack them at the four corners and in the center of each end. I then place them in the saw and cut off the required amount of end drop(in my case 1"), I then cut the required amount of coupon thickness(in my application this amounts to 3/8"+). Next, I turn the coupons over and repeat the same steps to get the other two coupons for a total of 2 vertical coupons and 2 overhead coupons. To remove the backing strips from the coupons I clamp the backing portion of the coupon in the vice and carefully grab the coupon with a vicegrip or between the jaws of a crescent wrench and rock the coupon back and forth until it shears the backing from the back of the coupon. Finally, I use a belt sander to shape up the coupon to the correct finish and shape and as well, radius the corners to the appropriate amount. This is a rough description of my method for preparation of test coupons. Regards all, aevald
