Up Topic Welding Industry / Inspection & Qualification / CWI Cert.
- - By Stallsmith (*) Date 01-16-2007 00:10
I am planning on taking my CWI in March or May.  I took a welding inspection course through a local college and feel confident to take the test without the seminar first.  I was wondering however which code (D1.1 or API 1104) have you guys felt was easier.
I have both but am curious of your opinions!!
Parent - - By 1316 (**) Date 01-16-2007 03:23
[deleted]
Parent - - By Stallsmith (*) Date 01-16-2007 15:49
Yeah easy is the wrong word!
What I meant was I have studied both for teaching my students.  I am more familiar with D1.1 but have heard others say that since API 1104 is smaller it might be better to take the code part on that.  I use the D1.1 more but have not read it through.  I have read the API 1104 from cover to cover.
Parent - - By UCSB (**) Date 01-16-2007 16:50
I took my first test (30 years ago) using the API 1104 code. Mistake. I worked with AWS D-1.1 mostly and thought the same thing--- smaller code, easier test. I found that since API was small, they had to dig to find enough material for the test- thus questions that you would not normally consider studying for.
I missed the cut-off by 1 point on that test.
Take the test using the code that you predominately work with.
Good luck
Roger
Parent - - By Stallsmith (*) Date 01-17-2007 16:36
Thanks Roger!
I use D1.1 more and that's probably the best code to use.  I also understand the number of questions went up for the code part from 46 to 60 something.
Does anyone know if that is correct?
Parent - By Ram_ (*) Date 01-17-2007 20:46
I don't think the number of questions have increased. However,AWS has the  QC1 2006, there it shows to have 46 questions, but it shows an intering note. Check it out.
here is the link:
http://www.aws.org/certification/docs/certqc1-2006.pdf
Look up section 6. Note it says "Minimum number of questions"
good luck!
Parent - - By RANDER (***) Date 01-17-2007 21:04
Yes the test now has 60 questions for API 1104.  I agree with UCSB that we will probably have to dig deeper to find answers.
Parent - - By hogan (****) Date 01-17-2007 22:03
D1.1 is so well indexed, this is the reason to use it.
Parent - - By Ariel D C (**) Date 01-18-2007 05:24
Im not familiar with 1104..but I used it 12yrs ago. Just understand the question and immediately refer to the table of contents to get the page for answer. Don't use Tabs...this will only slow you to get the answer. The key is to undesrtand the table of contents.
Parent - - By Stallsmith (*) Date 01-18-2007 13:11
Thanks Guys!
I'm glad I asked the question because I am more familiar with D1.1 but others suggested the API1104 because of the smaller book size.  I think I will stick with the D1.1.
Thanks Again!!
Parent - - By TTONKA (*) Date 01-18-2007 16:20
Why test on 500 pages worth of material when you can test on 100 pages worth?
I have seen several guys fail the D1.1 portion of the test.
Time is the enemy and if you tab the material in API 1104 it is easy to find and you will have
more time to go back and search or double check the answers.
Just one man's opinion who passed with API 1104.
Parent - By 803056 (*****) Date 01-20-2007 03:01
The exam questions are taken from the main body of the D1.1 Code. The Annexes and the Commentary does not provide a basis for the exam questions. Therefore, the number of pages you have to be familiar with is reduced to about 230 pages.
Parent - - By dbigkahunna (****) Date 01-18-2007 13:34
I took the test in august using 1104. I am fairly familiar with the code and it still took me almost the whole 2 hours. And one question I figured and figured on, gave the answer right out of the code.
BABRT's
Parent - By CWI555 (*****) Date 01-19-2007 21:42
It's my impression that there is no real advantage one way or another. It depends on what your used to working with. If you have more time with D1.1 use it, or 1104 if thats what you have used more.
Parent - By amr Date 01-20-2007 23:53
plz i take cwi course but i delayed me exam, i want some help understanding part B can any one my E-mail:amr_aerospatial_2005@yahoo.com
Parent - By maxilimiano (**) Date 01-20-2007 08:46
morning gentlement.
I am confused with your question..If people take an training course, because that people want to charge their brain., they always thirsty about knowledge...No matter how difficult that was...Because, study is likely a hoby.
Be the best...:)
