Up Topic Welding Industry / Technical Discussions / 17-4PH Weld Procedure
- - By jkbell2 Date 01-17-2007 15:01
After welding and post weld heat treating a test plate at 1150 deg F the mechanical tests were performed.  It it necessary to perform additional testing to cover subsequent solution anneal and hardening performed at various temperatures depending on the use?
Parent - By jon20013 (*****) Date 01-17-2007 16:16
Depends on a number of factors; are you trying to qualify to ASME IX?  Are there constructing codes or specifications involved?  Your question is good, but we need a bit more information to give a good answer.
