Yes ESAB was Linde a few years ago.
Never heard of that model but in case you arent aware the torch is what gets the water cooling not the machine. Most water cooled set ups use a pump and radiator in an inclosed system (addition to the machine) but there are setups that use city water, pretty wasteful I think.
Also if the machine is only 10 years you can attach a foot pedal that allows you to controle your starts, stops and heat. HF with out a foot pedal it can get interesting in tight spots, not to mention thrilling and blinding.
"Lift start" requires touching the electrode and pulling back. Imparts some tungston in the work and forces you to pull you gas purge away from the puddle to break the arc.
To bad you are not in Houston, we plan to auction quite a few good machines very soon.
