Isn't SMAW Shielded Metal Arc Welding? MIG in plain talk? MMAW is stick, Manual Metal Arc Welding and that uses the flux covered rods. MIG uses exactly the same 'fluxing' / inert atmosphere techinque as TIG (GTAW, Gas Tungsten Arc Welding). I don't understand why we have these names, MIG / TIG / Stick are much more self explanatory. Chuck, all it means by reverse is the polarity of the electrodes is reverse, obviously. The wire from your MIG is then the positive and the work the negative. Lots of reverse polarity welding is done in DC. It makes the bead much smoother as it runs much hotter, current meets the higher resistance of the wire first I guess. For your aluminium this would be a concern like one of the posts says because you really do need to get it the weld hot. You find that if you buy a MIG set you will weld with one polarity using inert gas and another using the flux cored wires. I _think_ it's reverse in gas. Must have something to do with the temperature of the flux and getting the best vapourisation of it. All you do to reverse polarity is swap the connections over on your welder's front (Make sure it has some method of doing this). Some have switches but if you haven't paid for it you don't get it. It took me quite a while to learn to use MIG properly as I had no one to teach me (The breakers went every four seconds as well) and I really do heavily suggest you get someone to just look at the beads you run to say whats wrong. I gave my brother a hand reluctantly after him mocking me when I bought I MIG welder for christmas 2000, and he was able to run near smoothish looking beads in about a night after only a few goes. Not very strong welds at all but close to being alright. Everyone I've met always tries to run the thing along like they're on Aliens or something, like 10 meters a minute. I find it's best to think of it like soldering, you draw a bead on the wire and drop it onto the work then move it along, trying to maintain that blob as long as you can without breaking it. TIG is so good on aluminium because, of coarse, the heat involved forms your oxide real fast in open air, even in an 'inert' gas atmosphere. The funny thing is that the aluminium oxides are removed by switching the polarity of the arc. So you could strike an arc, stop, change polarity by hand, strike another and then it would clean away the oxide. That's humor for you. So aluminium is usually welded on AC which swaps the polarity many tens of times a second. One heats, the other cleans. I had a dream last night that after 2 months working every night at ASDA from 12pm to 7am I would be able to afford an AC Esab Handytig and auto-helmet. I couldn't sleep for hours, I think I might need counceling. I'm not sure if I'm right but I think it was MIG after TIG because MIG was used to fill the demand for really quick welding, TIG is far from quick. TIG AC runs a high frequency over the arc's current to keep it very stable. I've yet to look into pulsed modes on MIG.
The fluxes in OAW and MMAW are corrosive though and if you do choose these you might be better off looking for some seriously powerful solvent to clean them off, as well as an angle grinder wire brush attachment (Don't let it roast your work while you're polishing it). I believe the Tetrachloroethylene and Trichloroethylene solvents used in laundrettes are used for removing grease films on metla but I'm not as to how good they are on fluxes. A !VERY! serious note: BOTH these solvent decompose in arc radiation to !PHOSGENE!, you !MUST! take extreme care with any solvent near welding (Like wearing a full face respirator and doing outside with a fan on). If anything I've said confuses you, except my fantasies about Esab, let me know.
Take care,
John
