Up Topic Welding Industry / Inspection & Qualification / Ammeter
- - By Duke (***) Date 01-28-2007 19:59
I need suggestions on purchasing a decent tong ammeter, I don't need it for all the fancy electrician stuff, just want to test welding voltage/current, you guys know what I'm talking about.  Can I get something decent for around $150, I don't want trash, it needs to be able to take a bit of a beating.
Parent - By Mwccwi (***) Date 01-28-2007 21:56
try Fluke 363 -600 amp/volt with digital read-out. I get mine calibrated yearly and it seem pretty tough I drop or knock it off off tables regularly and it keeps on working going on 4 years with the same set.
Parent - By thcqci (***) Date 01-30-2007 14:59
I have a Fluke 36, an older, obsolete version of this Fluke so I recommend it also.
Parent - By Logan Mayfield (**) Date 02-01-2007 14:29
I also use a fluke model 336.  It is 600A AC/DC.  Fluke is very durable but a bit pricey.  This model was closer to $250.  I am sure you can find one without all the bells and whistles that will do what you need for less.
Parent - By ssbn727 (*****) Date 02-02-2007 04:40 Edited 02-02-2007 04:42
Hey Duke!
Compare this one to the Flukes that have been suggested and see which one gives you more towards what you're looking for...
http://www.valuetronics.com/vt/assets/pdfs/BK_325.PDF BK Precision or Fluke:
http://www.valuetronics.com/vt/assets/pdfs/FLUKE_320_330SERIES.PDF
Here's one supplier that's reliable with very reasonable prices or you can buy direct if you wish:
http://www.valuetronics.com/index.aspx
Either way they're both excellent brands of equipment and of course, I've used both with great results either way!!! Good Luck in your choice!!!
