Smokey71,
very interesting!
After I have read what you have explained and as far as I have understood it correctly, the only issue has been changed was the base materials Heat No.(?).
May I ask if you have conducted such a kind of comparison between a piece of "older" or former base material where the phenomenon has not been observed, and the "newer" or current base material where the surface-cavities generation occurred?
For instance by welding a bead on plate under holding all surrounding parameters constant but only changing the base material?
Regards,
Stephan
P.S. A heartfelt "Thanks" for the kind and trustfully words coming from Darren and Allan!
