these requirements are for welds in tension and subject to cyclic tensile stress. they are required because there is a stress riser at the thickness change. the stresses are concentrated at right angle of the thickness change. a pjp weld has a stress riser built into it (the unwelded opposite of the root). so transitioning it can not eliminate the stress riser that is inherently part of a pjp
