Mark,
If it's ASTM A36 2" thick, I believe everything is fine if they preheated to 300F, the figures listed in Table 3.2 are minimums. No worries, unless they got carried away and exceeded 1200F.
Note that A36 shows up in Cat A (A36 2" = 225F) and Cat B (A36 2" = 150F), but the difference is whether they used SMAW Lo-Hy or not(read the notes).
Also note that the preheat is dependant on the thicker of the materials to be joined. (plate?beams? whichever is thicker)
