Up Topic Welding Industry / General Welding Discussion / inverters
- - By elliott fama (*) Date 02-04-2007 13:20
hows it going everybody, I got a question on inverters. I was wondering what you guys thought about the miller dynasty 200dx or the lincoln inverter 205.I was just wondering which machine you think is abetter machine. Im interested in buying but not sure which one yet,any feed back would be great thanks alot
Parent - By 357max (***) Date 02-04-2007 19:32
Go with the Miller 200 Dynasty DX which has the pulsing option. Unless the other brands have changed, Miller allows the full welding amperage output with full AC weld output with full pulse capability. The others limit the machine to full output with limited pulsing or full pulsing with limited output. Try them both at your distributor, before purchase. A good test is worth more than a thousand opinions. The fan on demand is a great feature, especially at low amperages.
