Up Topic Welding Industry / Technical Discussions / Infomation on High Frequency
- - By arcboy (*) Date 02-04-2007 18:30
I need some info on the technical side of High Frequency.  I need to know things like how it works why it is necessary for GTAW aluminum.  I don't have any specific needs just need to know as much as possible.  Thanks.
Parent - By 357max (***) Date 02-04-2007 20:04
First the High Voltage HF AC gets the tungsten "hot", then the flowing shielding gas gets hot and creates plasma. This allows the gas to conduct current. Just like the four foot fluorescent bulbs.
On AC it stabilizes the arc to force the AC to pass through the "0" line when it changes direction from electrode positive to electrode negative, negative to positive. The time at electrode positive provides the oxide cleaning action desired for aluminum. On squarewave ac machines the change to positive to negative, negative to positive is pretty fast and hf could be turned off. Not as smooth and arc but it can be done.
Parent - By Lawrence (*****) Date 02-05-2007 03:25
Parent - By brande (***) Date 02-10-2007 04:40
Hi-Freq. stabilizes the AC arc by ionizing the gas shield. This ionization enables the restart of the AC cycle after it passes through zero potential 120 times a second. ( in 60 Hz countries).
Hope this helps
brande
