I am reviewing a UT procedure and find that the standard a-b-c = d. is being called for. the acceptance criteria is per table 6.3 cyclically loaded non tubular. Up until this point, it made sense. What I am seeing is the inclusion of a DAC curve, but using the A-B-C for acceptance. It's my understanding that Annex S could be used as an alternative procedure. It's further my understanding that the two cannot be mixed, your allowed either, but not a DAC curve using abc acceptance criteria. Contract documents only call for D1.1 2006.
with that said, I am looking for opinions preferably ones that are code based as to if I am properly interpreting the following.
A) Can you or can you not mix a DAC curve with the A B C formula
B) With no other specific contract document other than the call for D1.1 2006, should the requirements or should they not of section 6 apply?
Thanks in advance for any responses.
