Up Topic Welding Industry / Technical Discussions / Socket weld gap
- - By dileep Date 02-13-2007 09:23 Edited 02-13-2007 09:34
What is the difference between a Gap-A-Let and a Gap-O-Let.  I think one is water soluble and the other one will remain as it is after hydrotest. can anybody clear this ?
Parent - By 357max (***) Date 02-13-2007 15:42 Edited 02-13-2007 15:57
G.A.L. GAGE Co.'s GAP-A-LET is a stainless steel split ring designed to give a pre-measured 1/16" gap for socket welds. Socket welds may be upset pipe or couplers, crosses, elbows or caps. Sock-O-Let and WELDOLETS are tradenames for socket weld pipe fittings.
Parent - By MBSims (****) Date 02-14-2007 04:52
GAP-A-LET:  http://www.galgage.com/socketweld.html
GAP-O-LET:  No such thing.  The "olet" fittings are a trademark of Bonney Forge. http://www.bonneyforge.com/branch.cfm
Parent - By prefab Date 02-23-2007 14:50 Edited 02-23-2007 14:56
The water soluble socket spacers are called Shur-Gap which is a registered trademark. They set the correct 1/16" gap then will dissolve, leaving the system clean but with the required gap.     www.abpaper.com
