Up Topic Welding Industry / Technical Discussions / Docol and Domex materials
- - By jerry6004 (*) Date 02-15-2007 17:29
B2.1 - 2.3.12 states that "Base metals not listed shall require qualification testing".   Where does it say what that tesing is?
Parent - By 803056 (*****) Date 02-16-2007 02:48
I believe they are referring to the welded assembly, not the base metal by itself. I believe the normal regiment is bends and tensiles, unless notch toughness is a concern or you are testing surfacing welds for abrasion or corrosion resistance.
Parent - By G.S.Crisi (****) Date 02-16-2007 19:28
Based on "horse sense", I'd say that the testing procedure for not listed materials is the same that listed materials must undergo to be approved.
