Up Topic Welding Industry / Technical Discussions / Base material Testing
- - By jerry6004 (*) Date 02-15-2007 18:15
If a material is not listed in B2.1, what type of testing is required to qualify the base metal?
Parent - - By 803056 (*****) Date 02-16-2007 02:45
I do not believe the base metal to be welded and qualified has to be listed in B2.1. However, if it is not listed, it does not have a M number assigned to it, thus the procedure qualified is lilely to be limited to the base metal used to qualify the procedure.
Good luck - Al
Parent - By Bill M (***) Date 02-20-2007 14:32
I am curious what is your base metal?
Is your base metal listed in ASME IX?
