I need to build up worn/broken cog type parts that see metal to metal contact. The parts are cast manganese steel, (nom. chemistry 1%C, 14%Mn, 1%Cr, 1-3/4% Mo.). In manufacturing we use a 309L FCAW to attach or join the casting in non-loaded areas. The worn areas are "as cast" and need base metal build-up, up to total replacement of broken / missing edges. Then re-shaping with a grinder to return to the "as cast" profile. Any thoughts on proper procedures, filler metals, heats, etc. would be appreciated.
