Question: Corner joint C-U2a-GF (pg 92 D1.1 2006)
Can this joint be used in the horizontal 2G position w/ FCAW?
Welding Process =FCAW, E71T-1 gas shielded, pre-qualifed wps only, root opening 1/4" minimum.
My original answer was "no" because "allowed welding position" column lists F,V OH it doesn't say H=horizontal. But then I read further into the code and note "E" says "SMAW detailed joints may be used for pre-qualified FCAW". So if SMAW can be used in "ALL" positions, and SMAW joints can be used for FCAW, I should be able to use FCAW in all positions right? As long as I go w/ the approtiate r/o and bevel angle (which would be 1/4 r/o and 45 degree)
Thanks Chris
