AWS D1.1 2006 list most of the requirements in section 2 Parts A-D
A is general requirements for all
B is specific requirements for static and cyclic non tubular
C is specific design of non tubular cyclically loaded. Which I believe is where your at based on your post.
AWS code will tell you to comply with the drawings. Only the Responsible Engineer can change them.
Part C in particular will cover the data your requesting, however; it would be the wrong advice to tell you to ignore the requirements of the design drawings/documents.
