Up Topic Welders and Inspectors / Welding Equipment Classifieds / NEED PARTS for 4 CYL CONTINENTAL on SA 200
- - By npartin Date 03-19-2007 22:35
  I need a rear main seal kit for the engine on te SA-200- F163   welder works GREAT but has oil leak at rear main and cannot find  a source for the seals...   a source for all the continental engines would be IDEAL!!! thanks
Parent - - By 2003440 (**) Date 03-20-2007 04:42
Call larry at weldmart he will get you linned up with what you need, you can go to weldmart.com he is very helpful.800-460-6474,hope this helps.
Parent - - By npartin Date 03-20-2007 21:51
thanks...  as for the seals I found an old Felpro ###  in an old book I had lying around the house  I put the local auto part store in charge of gettin the new PN's from Felpro and should have the seal in hand by friday.
Parent - By TozziWelding (**) Date 03-20-2007 23:44
My parts genius at NAPA can get me everything I need for my F-163. All I did was give him all the info off the tag.
