hi,
i am not asking a single person to tell me about all those problems. whatever is known to you, you can tell. explanations:
1. plz explain something abt microstrucure of weld metal also (like explained in 2nd post by sir)
2. if u ve ne snap shot of microstructure wm, bm and haz then plz do send on my email
3. also tell me which etchant shud i use for micro and macro structure of these (A516 grade 70 weldment) bcos i have been using nital but structure what i am getting is very poor.
4. and plz comment on hardness of bm, wm and haz with quantitative values (like which is having higher hardness - wm or haz)
5. how can i calculate the exact length of the haz - is it using microstructure or hardness graph
6. i have done impact test at room temp for pm, wm and haz but i dont have std impact values of pm, wm and haz at room temp to compare whether my results are correct or not
7. what type of conclusion can be drawn from comparing tensile, impact, bend, hardness test and microstructure of A516 grade70 welded with E7018 using smaw and gmaw
7. can anyone tell the % monthly interest rate of equipment and ownership cost for equipments like smaw welding rectifire, gmaw rectifier unit with spool unit in his respective country
8. last but not the least what shud be the approx deposition rate, deposition efficiency and operating factor of smaw and gmaw welding.
hoping now it shud be clarified:
thanking you,
gautam
gautam.lntecc@gmail.com
