Gentlemen,
There is no debate here. It was stated quite clearly up front that it would only be valid as long as the criteria for AWS was satisfied. What Al did was detail the difficulty of complying with this requirement. And this is true. Mos to ften the data wll probably notbe available.
But the point is, the qual don't know if its D1.1 or Section IX. If you have the data you have the data. If you don't you don't.
And the lesson here is that it wouldn't hurt to make your data more comprehensive when testing in the future. There is no reason why one qual can't be used for both as long as you are attentive to the requirements of each code. Or any other code for that matter.
803056,
I use both at the same time during testing (both plates halves having the same heat number); yes I believe they are the same. Most MTRs state ASTM A-36/ASME SA-36 in product description or specification. The plate that is ordered for our PQR & WPQR testing show this.
ASTM A36 is listed in QW/QB-422 as ASME SA-36 . SA-36 is a P1 (G1) material,where as A-36 would be considered a S1 (G1). I understand that it does not actually show A-36 in QW/QB-422, but in QW-420.2 anything designated a certian P# plus G# automaticlly covers corresponding S# G#, but not vise versa.
P# indicating SA-XX(X) (ASME), where as S# indicates A-XX(X) (ASTM). The example of SA-240 Type 304 in QW-420.2 is a good example of what we're are talking about.
It sounds like you have a good handle on matters.
Now consider how it would play out if you did not have the MTR, only the PQR, and if the PQR listed the material as A36 which is listed as S1, you would not be qualified for SA36 listed as a P1. S1 does not qualify for P1, whereas P1 does qualify S1. A procedure qualified to AWS using the A36 would not qualify for SA36 due to the differences in S and P numbers.
As others have noted, document, document, and throw in the raw data for good measure. I have my clients keep the CMTR, lab reports, and I record both the visual acceptance criteria applied to bend samples as well as the thickness and the bend radius on the PQR just in case there is an audit or if there are questions from a customer. That's why I do not use the sample PQRs provided by ASME or AWS. I record much more data than the standard formats require.
You just have to love these nuances.
I included the URL for www.pnumbers.com because it is a good resource for those of us that work with both ASME and AWS. Typically ASME SA or SB XXX materials are assigned P numbers, whereas ASTM A or B XXX materials are assigned S numbers.
By castle
Date 03-23-2007 19:29
Edited 03-23-2007 19:32
803056,
I see your point concerning the A36 material crossover from a PQR with D1.1 to IX. Thank you very much for helping me see a possible pitfall that may occur on my side if I did not value the usefulness of the MTRs.
Welder Qualification would not matter though.
-Rick
I can see you've been through this hoop before Al. In addition to what you brought up as valid concerns, are variables in the testing requriements. For instance, if you compare the bend radius for materials in ASME, the requriement is based on the materials requried elongation, while AWS D1.1 bases it on the materials strength. In ASME, you can also use round transverse tensile test specimens, but not so for AWS. Currently I'm trying to qualify some aluminum procedures. Our customer is specifying qualification according to Bureau Veritas Rules. We also do work to ASME and AWS D1.2. It would be nice to get qualifications good for all of them, but it is hard, if not impossible to comply with all of them. For instance, different widths of the transverse tensile tests are requried. Different bend test radii, macros vs no-macros, NTD tests and acceptance criteria, etc. It gets quite complicated. Not to mention the different qualificaition ranges. Different thicknesses, positions, parameter ranges, heat input requirements, number of passes, filler metal requirements.
I often find the bottom line to be that you can often comply with several specifications if you know before hand and test to the most stringent requriement. Sometimes it would even involve multiple specimnens for the same types of tests. If I am trying to cross over a previously qualified procedure, I will get lucky sometimes if documentation was adequate, but as often as not, there is something that wasn't quite up to snuff. That is one reason I always save tested specimens and test plate remnant. You never know when a customer will want something different.
Well GR, I couldn't agree more. Well said.
I reject about 85% of the PQRs and WPSs qualified to Section IX that I review because the contractor didn't review the requirements of the applicable construction code. How can they meet the requirements of other welding standards if they don't even meet all of the requirements of code they were supposed to meet?
I'm not saying it can't be done, but, as you stated, you need to know all of the codes and standards up front before striking the inital arc if you expect to meet all the requirements, and again as you stated, there may be some additionals tests necessary to be fully compliant. A good argument for keeping the bend samples and the remants of the test coupon. Well done.
