100% argon will provide a ropey and convex GMAW weld bead. Addition of 1-2% oxygen or CO2 to the argon will wet out the weld and help it flow.
There are two Tri-Mix gases for stainless steel, for short circuit it will be 90% helium, 7 1/2% argon and 2 1/2% CO2. For Spray & Pulsed Spray a 94% argon, 5% CO2 and 1% Hydrogen.
Gas choice will be more influenced by post weld treatment (disregarding the issues of carbide precipitation, mechanical properties & corrosion resistance); as welded, grinding or polishing.
