aditya,
this summer i had the same situation, i prepared WPSs from two PQRs, 1(1)-1(3) and 4(1)-4(1)
in Sec. IX QW-256 and 253 indicates essential supplementary and non essential variables for GTAW / SMAW process.
QW-403.5 for group number
QW-403.11 for p number.
in QW-403.11 sends you to QW-424, you will see p4 to p4 base material qualifies p4 to p4 or p3 or p1 (up to here no problem )
in QW-403.5 it says simply, when base metals of two different P-number group number combinations are qualified using a single test coupon, that coupon qualifies the welding of those two p-number group numbers to themselves as well as to each other using the variables qualified.
i can say, to write that wps you need group number 1 to 2 or group number 1-3 p number 1 or group number 1 to 2 p-number 4 PQR
regards,
T.
