Up Topic Welding Industry / Technical Discussions / Low point vent and a high point vent
- - By sabir (*) Date 03-28-2007 03:12
What are the criteria for using a low point vent and a high point vent in pipeline and piping, other than for hydro test?
Parent - By dbigkahunna (****) Date 03-28-2007 11:19
On X country DOT regulated pipelines it will depend on if it is a liquid or gas line.
Parent - - By MBSims (****) Date 03-28-2007 21:24 Edited 03-29-2007 01:07
The low point drain is used for draining fluid from the piping system, such as for repairs or prior to inerting for layup.  The high point vent is used to aid in draining or to bleed air out of the system when filling.  I take it that piping systems are not your area of expertise?  You might want to purchase a Mark's handbook for mechanical engineers or attend an educational seminar if you would like to be more familiar with piping system terminology or design.
Parent - - By G.S.Crisi (****) Date 03-28-2007 21:29
Marty, let me make a little correction on your second paragraph. It's high point VENT, not drain.
Parent - By MBSims (****) Date 03-29-2007 01:06
Thanks Giovanni - typed a little to fast there.
Parent - By sabir (*) Date 03-29-2007 13:06
Can u suggest me any kind of online courses related to Piping, I'm a new bee into this industry...appreciate you kind advice
