For new WPS qualification per D1.1 (and also D1.6, but don't have a copy yet), we'll be preparing test welds on 3/4" plate. Process will be GTAW; base mat'l will be 4130 to itself; all will be for in-shop productions. (also have 17-4PH to itself in another future WPS, that's where D1.6 comes in later (thanks GR!)).
I need help in understanding how many test welds and tests I require, to qualify for "All Position". Must we weld up one groove butt weld for each of four positions (1G thru 4G) AND one T-joint fillet weld in each of four positions (1F thru 4F)? Will I need more test welds than this? or may some be used to cross qualify others?
Part 2 of my question is must we then have two Face Bends tests AND two Side Bend tests AND two Reduced Section Tension tests performed for EACH of the four groove weld test joints; additionally are two each Macro-etch tests also required for each T-joint fillet weld sample?
Part 3 of my question is according to an older copy of B2.1 (new 2006 version on order!), I must also have Shear tests done on fillet welds in a lap joint configuration. Which means I need to obtain four more test weldments (one in each of positions 1F thru 4F) and conduct two Shear tests on each.
Is all of this required or have I gone way way overboard in my interpretations?
All advice gladly received, and THANKYOU.
Coop
