Hello. At the moment I am trying to pass my ABS welding certifacations at the new Kvaerner ship yards in Philadelphia.
The vertical and horizontil flux core are no problem. The problem I am having is with the stick. Here is the question.I am using an invertec 300 pro. I am using 7018 1/8 rod. The welding specs say that the machine should be set on crisp smaw.
How ever I cannot get any good bead this way. When I set it on soft smaw. I have no problems at all. Could someone tell me for sure,with 7018 rod on low carbon steel. should I be set on crisp or soft? The last time I did any stick welding, I did not have this option. Thank you for your help and support.
