Up Topic Welding Industry / General Welding Discussion / hooking up plug for single phase
- - By elliott (**) Date 04-05-2007 20:56
how is it going guys .Got a question about hooking up a welder plug  for single phase. The black and white wires go to the pwer terminals and the green goes to the ground,and red is not used for single phase.Does any body know if that is the right way .Thanks for the info
Parent - By 357max (***) Date 04-05-2007 21:36
With the power off put the ac voltmeter probes into a 240 VAC receptacle's two hot legs. Now turn the power on. If it is 240 link the welder for that voltage. If it is 208 link accordingly. The green or yellow with green stripe or green with yellow stripe is the earth ground to chassis of welding machine. The white and the black wires on the cord are usually wired as the two hot legs. Tape off the red if it is a four wire cord.
In the house wiring, for 200-240 VAC stoves & dryers the use of 4 wires is to provide a separate wire for neutral and a separate earth ground. This permits 120/240 by using a neutral, one hot and the earth ground for the 120 and all wires for 240. Welders do not require 4 wires for single phase.
Parent - By darren (***) Date 04-05-2007 23:58
I think perhaps you should give a friend with some more experience some beer to wire your welder up. There must be someone around in your world who would be willing to help you. The price of a dozen beer is VERY minimal compared to all the possible things that could happen if the welder is wired incorrectly or proper safety procedures are not followed during the job.
darren
Parent - - By billvanderhoof (****) Date 04-07-2007 03:51
Begging to disagree- in a 240V single phase circuit the two hot leads should be the black and the red, the white is neutral, the green is safety ground.  If the equipment being serviced contains 120V components (often cooling fans, indicator lights etc) the neutral wire may be necessary.
Bill
Parent - - By 357max (***) Date 04-07-2007 15:00
Good point, That is if it is a four wire single phase connection the white would be neutral (separate from earth grounding). Single Phase Welders use three (two (2) conductors one earth grounding) wires; earth ground and two hot legs. Green is always, always earth ground the single phase's 2 hot legs can be white, black or red but not green. If white is used for 1 hot leg tape a length of black electrician's tape around both ends. This is done to show that the white is not a neutral conductor.
Parent - By billvanderhoof (****) Date 04-08-2007 02:23
Agree now completely.
Bill
