Up Topic Welders and Inspectors / Welding Equipment Classifieds / sa200 armatures
- - By fw3372 (*) Date 04-07-2007 16:40
bought sa200 complete  complete machine was rebuilt apparantly left flywheel bolts loose wiped both armatures need main and exciter armatures any one have these please call me 281 642 7706 .I work on welders but are out of these now
Parent - - By weldersales (**) Date 04-07-2007 19:07
We should have both armatures here. What is age of your SA200?      weldersales
Parent - - By tompit9 (***) Date 04-13-2007 07:33
do you have a web site?
Parent - By tompit9 (***) Date 04-13-2007 07:44
how much for an armature to fit a '55
Parent - - By thewelder (***) Date 01-22-2008 03:11
Hi,WELDERSALES. I'm lucking for sa-250 main armature, don't now the code# or serial# the face plate is mutiladed. can you help me? lucks like you now alot of this bus.THANK YOU.
Parent - - By weldersales (**) Date 01-22-2008 20:02
Hello Jaime,        Sent you a private message last night. weldersales
Parent - - By thewelder (***) Date 01-23-2008 05:41
Hi, weldersales, thank you for you'r help. I send you a private mess allready. Thank you.
Parent - By weldersales (**) Date 01-25-2008 14:56
Good morning Jaime,        You have a very rare machine. There were a few SA250 gas welders built in a large frame, the same as the Perkins diesel model. Then there were Canadian machines in the SA200 frame, but with the AC exciter sticking through the front panel. If you check the serial number, Lincoln will tell you the machine is a 48 model or some such. It is really a 90's model. The code number is on the front panel unless someone took it off. It is also stamped into the right side of the generator, facing front panel. You want to be careful because Lincoln used two exciter assemblies each using different bearings hence different armatures. Thanks,     weldersales
Parent - By raftergwelding (*****) Date 10-14-2007 18:03
still looking for armitures i have the main and exciter for a short hood for sale
Parent - By HYBRIWELD (**) Date 01-24-2008 06:30
FEEL FREE TO VISIT OUR WEBSITE CONCERNING ARMATURE INFORMATION.
