HELLO,
ACCORDING TO THE CODE, IT SPECIFIED ME THAT THE RECOMMENDED ALLOY FOR QUALIFICATION OF Heat treatable aluminum alloys IS AL 6061, BUT I HAVE SEEN THAT THIS ALLOY HAS SOME HEAT TREATMENTS THAT THE CODE DOESN´T SPECIFY, WHICH IS THE RECOMMENDED HEAT TREATMENT FOR THIS ALLOY FOR A QUALIFICATION PROCESS? OR IS IT DEPENDS OF OUR APPLICATIONS? OR IT MUST NOT HAVE HEAT TREATMENT?
THANK YOU
