Up Topic Welding Industry / Technical Discussions / coupon quantity for Ω weldng qualification in NB
- - By Junbao Zhang (*) Date 04-11-2007 01:45
consult about ASME NB,4366 and NB 4368 about coupon quantity of welding procedure qualification and welding performance qualification for Ω weld.
welding procedure qualification:
6 test assemblies or 1 test assembly each welding operator for automatic welding about Ω weld ?
2 test assemblies or 1 test assembly each welder for manual welding about Ω weld ?
welding performance qualification:
Parent - - By jon20013 (*****) Date 04-11-2007 11:44
So, whats your question?  Yes, these are welder / welding operator performance qualification tests for specially designed welding seals.
Parent - - By Junbao Zhang (*) Date 04-13-2007 01:58
YES,I want to know the coupon qualtity for seal weld welding performance and procedure qualification for each welder or welding operator.
IN NB4366
6 coupons for automatic welding procedure qualifiactin for each welding operator , or 6 coupons for whole procedure qualification for all welding operators ?
2 coupons for manual welding procedure qualifiactin for each welder, or 2 coupons for whole procedure qualification for all welders?
The same question for welding performace qualification.
Thanks for your reaction!
Parent - - By js55 (*****) Date 04-13-2007 13:28
Not sure what you mean by coupon quality but I'll take a shot. There isno specific reuiqrment for quality when qualifying anything for nukes. You do however have to have absolute traceability.
There for ethere is nothing special about performencae quals. Standard ASME IX methods are fine.
However, with nukes the most difficult part of WPS quals is the impact testing. And specifically the comparison of HAZ to unnaffected base metal.
The latest Section II revs have considerably lessened this problem but most nuke work is done with plants licensed to older revs. And lots of luck getitng them to recert the plant.
Modern steel making processes have created steels of extremely high quality and therefore it will be very difficult for your HAZ to equal or exceed the unnaffected BM.
The secret is to actually use lesser quality steel for your qualification. Large grained stuff as opposed to the generally understood high quality fine grained stuff. In other words SA-36 as opposed to SA-516. And stay away from normalized andnormalized and tempered stuff too. Use hot rolled plate for oyur quals.
The grains in the HAZ will refine with proper heat input and will demonstrate greater lateral expansion than the BM.
Parent - - By js55 (*****) Date 04-13-2007 13:29
Thats Section III revs by the way.
Parent - By js55 (*****) Date 04-13-2007 13:30
Sorry about my typing this morning.
Parent - By jon20013 (*****) Date 04-13-2007 18:57
Junbao Zhang: Try reading the subparagraphs following NB-4366... NB-4367 and NB-4368... you'll probably not need to ask this question... One thing very, very important in all code work, but most especially in nuclear work is to read ALL of the requirements, not just one part.
