Arc on time measurement, to me has always been over management IMO. I mean, if you are a supervisor and you don't know who your most productive welders are get another job. I can see a use for it in robotic applications, but semi automatic, or even machine is so indeterminative, I'm not sure the precision data means anything.
The one time I used such data was, as I said, to determine the overheating or overcpacity possibilties in my buss bars to make sure that I met OSHA standards, and got the maximum out of my plant without having to go to smaller machines or a bigger buss bar.
Arc on time averages can work very well in homogenizing your electrical draw.
Some of that also records the parameters, so you would know if a welder was jacking the machine up out of procedure when no one was looking. I had a few who thought they could make better time if they ran real hot and fast.
i cant imagine a welder ever doing such a thing ;)
By CHGuilford
Date 08-25-2007 01:32
Edited 08-25-2007 01:34
For those who are wondering..
Measuring arc-on time is a part of determining and managing the efficiency of a welding operation and it is not necessarily limited to robotic welding. Many other parameters are also recorded but knowing how much time is spent actually pulling a trigger can help determine if that new wire promoted by a salesman will actually pay for itself. Or if changing the ergonomics in particular operation will increase production while reducing risk of soft tissue injury. Or if a machine is really used as much as you think it is or would an upgrade be better spent in another area. And so on.
Measuring arc-on time normally does NOT evaluate an individual's performance. Well, it could - but as was said, counting how many acceptable welds have been made by the end of the day better tells that story. Now a really good welder is the one who sells the most raffle tickets, tells the most jokes, makes the most trips to the bathroom, or the toolcrib, AND lays down the "mostest" and prettiest welds.
PS
I forgot to mention, Onset Computer Corp has affordable dataloggers for various types of measurements. I have used some of those for measuring arc-on time.
