Up Topic Welding Industry / Welding Fundamentals / rancher tig
- - By Sourdough (****) Date 04-13-2007 18:50
Whose had to fill up a 1'+ crack before? Bust the flux off a piece of lowhy, and use 5p as your tungsten and lowhy as your filler.
Parent - By aevald (*****) Date 04-13-2007 19:08
Hey Sourdough, which code does that qualify you for? Barnyard 1.8 rev. 3 or? Yes, I believe I've done something similar before, just not on anything that really counted. Get-R-Done! Have a good one. Regards, Allan
Parent - - By webbcity (***) Date 04-13-2007 20:59
sourdough , hi from clayton , willie's son age 12 . not only does he type faster than me he spells better . sound's like the "rock crusher code" that we use in the rain at portage . i'm going to anch. next wenesday if i get to tia i'll check on your picture . good luck . willie
Parent - - By TozziWelding (**) Date 04-14-2007 00:43
I believe up here in MA that is "bog"(as in cranberry growers(my Grandfather was one)) code. Those guys call you with cash in hand and want the job done ASAP(they broke it today, and want it fixed yesterday).
Parent - By Sourdough (****) Date 04-17-2007 23:30
"you might be a redneck welder, if...."
Parent - By Sourdough (****) Date 04-17-2007 23:33
Excellent old fashion name!!
