Up Topic American Welding Society Services / Certifications / Understanding a PQR & WPS for ASTM A514
- - By kdkimball Date 04-13-2007 19:29
My head is hurting from reading and re-reading section 4 of AWS D1.1, can someone please help?
I have a manufacturer that has what appears to be an approved PQR for welding ASTM A514. The PQR is for 3/8" thick plate using a single v-groove weld, butt joint. Does this PQR and subsequent WPS qualify this manufacturer to weld ASTM A514 plates thicker than 3/4" utilizing single or double v-groove welds?
I don't think that it does, but my head is spinning after trying to consider all of the little foot notes included in the tables for section 4!
Thanks in advance for any help you can provide.
Parent - By RANDER (***) Date 04-16-2007 20:01 Edited 04-16-2007 20:25
I appears to be a rather straight foward Max = 2T or 3/4" in your case however one of the structural guys may have a different answer.
Assuming it's a CJP joint
